IC Chiller install & review
Thread Starter #141
Just redid lines to have more room for plug changes and it look cleaner. Will get some thin vibrant heat wrap. Does anyone know the part number for that stuff?
I see you chose to make sure that low side suction line & T block were placed differently based on my experience. Lol.
Mine is about 1-2" further toward the firewall from the looks of it and the metal portion with the female screw on fitting is positioned such that the rubber hose made significant contact with the head/valve cover mating surface which is what caused it to loosen up.
Good work man!
Thread Starter #143
Yes, I had to swing
Good work man!
Thanks! yep, I had to unscrew the very tight fitting to the compressor, swing it in, mount, indexed with marker, took it off compressor, and then tightened it with AN wrench and adjustable wrench holding fitting. I redid them last night, the lines have play in them but very minimal. I tightened everything really well, we shall see
Thread Starter #144
@fubar569 if you mount the hose as it comes (screw on fitting already really tight to cnc compressor fitting), it mounts like this, which is no bueno. So I took it off, cracked it loose, fit back on, hand tighten, index with marker (I swung it in closer to block/compressor) took off and tightened
Thread Starter #145
🥶🥶🥶 3 mins after startup driving around (drag valve on), IAT plunges when going wot. (Yes my gauges are flipped)
Thread Starter #146
Also, stock 1234yf, as it should be. Zero leaks. Expecting the compressor to live a long time
Thread Starter #147
All I can say is wow, idle for 5 mins. Supercharger is cold. As everyone knows, with older hellcats the gauges are flipped. I/c coolant temp is actually IAT, and IAT is actually I/c coolant temp. So 26* coolant temp. Once you get on the car a bit or wot IATs plunge. They’re still below ambient at idle (which is awesome!) but they plunge more when you have more air flowing over the supercharger bricks
catdad
Lake City
Nice temps, I may have to update my kit to the block exp valve. How much freon did they put back in yours?
Thread Starter #149
28.5-29 because the car calls for 25 stock. 1234yf. I guess I crimped and lubed all my rings good, zero leaks or issues held vacuum from a machine for an hour
Thread Starter #150
AC guy said expansion valve was working great. I can’t believe how quickly it gets cold, then again with all my hoses (stock tank) only took about 1.5 gallons of fluid when filling
Thread Starter #151
I guarantee you it would have went down cooler but was starting to p*** off neighbors
Thread Starter #152
My suction line is right up against my radiator overflow hope it’s ok like that. I bet it would get cooler if it wasn’t and I had it insulated
Thread Starter #153
I’m so glad I got it vacuum evacuated and then professionally vacuum filled
Thread Starter #154
Very impressed. I’m a believer now. I was expecting it to get down to 40 min
Thread Starter #155
I wonder what the coolest temp is for this thst people have seen on an 84 degree night
Suwanee
@Unholy707 hose for the Suction side from firewall is little longer due to different setup. We were reported that JLT required little different routing. So, make it little longer and let the customer cut it.
let me talk to Charlie and make a note that we put that somewhere in our documentation so the customer knows that they can cut that hose if needed.
Thank you so much for your feedback
Thread Starter #157
let me talk to Charlie and make a note that we put that somewhere in our documentation so the customer knows that they can cut that house if needed.
Anytime! Very impressed with the kit! Just in time for the track 🥶😎
Suwanee
Standard hellcats got 22oz from the factory as far as we know. We have found sweet spot between 27.5-29 on the stock blower cars.
What’s your pulley combo?
Thread Starter #159
2.69 upper only
Suwanee
