IC Chiller install & review
Thread Starter #81
Just got plastic sheet to close off wheel well vent
Stz wu B Hrk great wen yoz a tight gripster. Fill in das blanz ster. I amster a sheet Ramaflx maxttex mechanic. I have dun a milleon chillers. One waz Tampa Bay Mechancial onewaz B & H Insulation. A many of waz Cnentifegul, one waz absurtion an a pipe and pumps. Lottz of chillers and piping. I wurked ass annine project manager on a 3 ear manager ass anine all Rmaflex. Lalot frum da 20 erz guyz. All pipen and 1st ear chiller. A 1949 ear chiiae. An engineer caught wa swapen 2 truck loads of Rubatex fer Rmflaex at 1/2 da price of Armafilex. Remmemda da differance bee tween da 2. I waz stupid vigen 4 500 gallon tanks. An M & M Arz Union all butters us. Boy did day take it out on me. Non union wurkin on union job. Day had a ball bustin rally fer da union guyz against us non union dudes. Went ova great. Yea.? We wurst da last peoplez dare We alsoz wurked at a uninonz shop in Al bam erz. Hot pipen dat wood fry fiberglass. And calsil and wor and riggerked ass an crane operator and rigger fer big larger cranez. And insulator.
Thread Starter #83
They allow union in Fl? Lol
Thread Starter #84
And I really wish I understood half of what you type, because it seems like you have a lot of experience in the area
Thread Starter #85
Juuuust clears the bottom of the bumper - brick actually rests on it. Don’t run anything over or it’s toast lol. Way more room up front then I though - might change plumbing a bit
In Seaworld, Disney, de Cape yes union all da way. Butter snot any more. I waz a project manager, yes fer management. Surry butt Ize speak in broken english and slang. I picker upster in Tennessee. Lived dare fer 21 ears.
Thread Starter #87
Is that why @hellno talks in all caps lol
Yes Unwhul 1/2. I kinda do. 1 /2 project management dee outa 1/2 hanz on frum trades.
Thread Starter #89
plumbing is almost done finally. All routed through under the car. L coming off heat exchanger on passenger side of car under the car to chiller line, L coming off of cold side supercharger hard line on passenger side, hose running by headlight/down behind crash beam and under the car to the chiller. Just need to insulate and clamp everything down. Chiller side for bypass is all done. Amazon is late so my new fittings for the chiller won’t be here today smh
IMG_1694.jpeg IMG_1695.jpeg IMG_1696.jpeg IMG_1699.jpeg IMG_1700.jpeg IMG_1704.jpeg
Thread Starter #90
If you’re running the 3 way valve, it’s a bit of a project for sure to figure out the plumbing and route everything the way you want it. I will say the hard lines for the TXV get in the way, and limit how you can route your water lines.
Thread Starter #91
If you have an good budget, an fitting like @fumanchu182 ran are the way to go. Thankfully retaining the factory hard lines gives me some good locations to take it all apart if I have to. Current situation under the car : hardline (hot from supercharger to pump), heat exchanger (flow is reversed from stock, this is from passenger side to the T) and cold side sriracha front the chiller uo side of condenser/near headlight and to bottom of cold stock hard line. Still need to insulate and tie everything down, this was for mock up
Thread Starter #92
Coming together. Test fit bumper, hoses underneath (with insulation) clear bumper and splash guard
Da radeeator snd pipen is impressive. Guud job. id luv 2 have da monies involved wit dis install. Did I sea SPI written on sum of da Armaflex?? My go 2 supplier for 40 ears. Tampa, Fl. I had Sandi Hibbard was my account exect vary guud gal.
Thread Starter #94
Lmfao I got a gauge manifold and a vacuum filler for the coolant too. Not going to mention how much $ I have into this on top of the price of the kit
Thread Starter #95
Do yourself a favor and don’t run the 3 way valve. If it doesn’t cool to my likings I’m going to rip it out. Really over complicates the install
Thread Starter #96
Garage is a war zone, still a lot to do, not 100 % how I wanted it, but install is starting to turn out clean
Since you removed the air to water heat exchanger (little radiator) Where did you route the other port of the 3 way valve too then?
Thread Starter #98
The other side of the big heat exchanger. So the big heat exchanger is “bypassed” (fluid will not flow through it end to end) during normal operating, and then fluid is directed into it when button is on
Thread Starter #99
This is the diagram I used, set it up pretty much exactly like it. This is the “updated” diagram from IC
Thread Starter #100
Just said to heck with it and used the metal fittings. They just clear. The cold side out is only barely hand tight because I of house I had to index it and there’s no way I’m getting a full turn out of it. Hopefully the PTFE paste seals it and hardens a bit. Vacuum fill tomorrow morning after it has a chance to cure a bit 🤞🤞🤞
