Just checked the security system and cameras on it. All is well.[lockdance]
Give me a few weeks we will have it out!
Slimcat
Jacksonville
NC
2016 Challenger SRT HC
Put blackout on the rear reflectors, and side markers. Now everything is black/White except the tail lights. I will get a pic later.
I did the same a while back - subtle but looks great on white/black hood combo
Built a a front tow hook mount for the 170. I'm waiting for a right angle drill attachment and someone to help me drill holes straight, then I'll install it.
Also, there's recover holes in the "frame" under the car, for those that can't mount a tow hook to the front. Those spots can also be used as tie down locations
I have not found a way to tow from under the car w/o damaging the air dam. Ok for strapping to a trailer. Am I missing something?
HangZhou
China
For the road trip, I bought a locking gas cap for safety. On the way back, I stopped for gas and realized I’d lost the key. Had to pay a mechanic $21 to unlock it — took him two seconds.[rofl] (By the way, does the car have an electronic speed limiter from the factory? Top speed 250 km/h?)
Maybe overseas they are limited. Otherwise it should go way over that
From what I have seen the limiter is set to about 203mph (U.S.). Top speed will vary due to the diameter of the tire and inflation.
https://www.hellcatforum.org/threads/in-search-of-200.16176/
my OE tune file says 254 mph speed limiter via fuel cut :eek: [driving]
Local with a 2023 found stock config was 203. Fits what I have seen.
06SRT10NR
Knobnation
might this be model year dependent? or perhaps the stage kits?
I don't have images, but several years ago, my '15 HC M6 and '18 Demon [crate ecu] showed the same or similar as @drag racer
edit: '09 Challenger SRT8 M6 I traded in for the 15 HC also showed a number the car could never hope to achieve, well over 200, don't recall what it was though.
TorRedHellgato
New York
2020 Dodge Charger Hellcat
Had the Hellcat towed to the shop today. Didnt want to drive it to the shop with all this slop on the floor.
Added this 2024 photo to my screen saver.
I don't know what exactly you are posting, but the image I posted was a stock 2023RE.
I hit the speed limiter somewhere around 205 before reaching 1.5mi. Speedo never went above 202.
...from my 2016 Hellcat OEM tune file
Interesting. Obviously things have changed over the years. In 2024 a young lady in a stock 2015 did 190 in the 1.5mi. My stock 2022RE did 195. It is possible they did adjustments on the later years... :mad:
Big day! She hit the ground nearly ready to run.
1. Check and hook the battery back up. Trickle charger said it was too powerful to top off this morning. Fuck it, when it is time I’m hooking it back and firing it up. Lithium is the shit!
2. Prime it turnover once, THEN, start, check oil pressure, double check the level.
Done, ready to rumble!
WTF....seems like all that sun..went to yer brain....yer jumpin then gun...we got a lotta winter left
