- #997
- 5,172
- 9,640
- 402
- Houston
- TX
- 2017 Challenger Hellcat
heres something to add to the info about my car ,only hpindy knew that I had already addednthe 10% overdrive to my car last monday without any other changes I still have the demon injectors and im running 17 psi and if you would like to see the logs the injector duty cycles at redline got as high as 93 last night but sunday in the 1/8 mile highest we saw was 83 but no always the reason they didn't totally max out was because of the jms and fuel pressures at 89-94 psi my lamda readings were fine and never showed any issues ( curt has seen the logs and even he was surprised it didn't max out the injectors) I did pull 3 degrees of timing out of my pump gas tune and I raced it last night with the original race gas tune I did have the octane at 110 when I got the 9.95 pass I had actually added 1 degree of timing to it but as you can see my 60 ft was bad because I spun off the line ,then I took the 1 degree back out and made the 9.92 pass after waiting two hours to run it again because of track issues and someone getting run over by scooter on the service road it still didn't hook the way I wanted and I didn't launch it as hard as I normally do but I did get it back down on the 60 ft
1
1
