Thread Starter #281
I had talked to hpindy earlier I believe had I only added timing up top instead of adding it throughout it would have hooked better I should have added it at wot only
when we starting adding more power - then the track prep becomes more of a issue & then it's hard to get our best et.
Thread Starter #283
I agree I’m going to work this week to get traction resolved
Thread Starter #284
I had it as much as 19.5 degrees of timing with no kr I gas octane set at 102-104 I did a 4th thru 6th pull in the hwy headed to the track and wow it was pulling hard and my logs show a very noticeable increase in torque
I can’t wait to see the 1//4 mile results
Are your tires still good ? …...I know mine are done.
I'm no tuner, but 19.5 seems high with pulley ?
Thread Starter #287
My tires are in very good condition I probably should have tried rolling into it , instead of caveman’s foot lol
Thread Starter #288
I had race gas in it curt with a 100 octane tune has it at 17.5 I logged and tested it to make sure there wasn’t any knock retard
Come on hellno , I want to see a 9.xx et out of that thing ! [loveboost]
I know he has it in there !
Thread Starter #291
After this weekend I’m finished with mods I’m leaving it alone it did well in the 1/8 mile and they said roll bar time for me
Thread Starter #292
I have to be happy with low 10s
I agree , the boogey man is in there , but once he's out it's hard to put back, LOL.
I'm with you brother , 10.0's is plenty fast & very respectable.
Not too many cars can run low 10's without a bunch of work.
Definitely. 10.0's is extremely respectable in a street car !
As is your car Hpindy, very respectable at what now ?....mid 9's , just crazy !
My ultimate goal was 9.99 ..... Everything else is just curiosity now .
I bet you see it drop to 75 at times as well and even though your duty cycle is low when its dropping even to 75 psi your duty cycle will go up in turn ,it should stay at 79+ at wot if you log it you will see that the desired pressure is 80 at wot
Update - I did some logging in 50 degree air checking my tune. I did see the fuel pressure drop to 70 or so psi when aircharge was on up there and close to 6500 RPM shift point. Inj DC never went over 62%, Inj PW never went over 11, and lambda stayed at .82 - .83 so not something I'm concerned with but wanted to update with the observation. It seems a certain set of condition must be met for this to occur as other logs in identical conditions fuel pressure never dropped below 78 psi.
I've seen some Redeye logs recently and their fuel pressure was over 100 psi. Both of these are quite a bit more than my old R/T where 55 psi of fuel pressure was considered plenty.
Thread Starter #298
ISNT YOUR FPDC SET TO 100% AFTER ALL THE ISSUES I HAD WITH MY PUMP IF MINE DROPPED TO 70 ID BE SUSPICIOUS BUT IT MAY BE NOTHING JUST KEEP AN EYE ON IT ,I LOVE MY JMS MY FUEL PRESSURE HAS ONLY BEEN AS LOW AS 88 PSI BUT CONSISTENTLY STAYS ABOVE 90 AND SINCE I CLEARED THE P025D FAULT FROM CAUSING THE CHECK ENG LIGHT IT STAYS 89 T0 AS HIGH AS 94PSI WHICH IN TURN HAS NETTED ME MORE POWER AND MY INJECTOR DUTY CYCLE IS LOWER AS WELL
Be careful with the timing. I'd try to have someone video a couple of runs for you and focus on watching the exhaust. We can't 100% trust the knock sensors in these cars. If you're not seeing any STKR, you need to double check by watching for puffs of smoke from the exhaust as you go down the track. If you see any, it's detonating. If not you're G2G.
Thread Starter #300
I HAD A FRIEND BEHIND ME ON THE INTERSTATE WHEN I DID A 4TH -6TH PULL HE SAID HE SAW SOME GRAY LOOKING SMOKE WHEN I PUNCH IT AND THAT WAS IT BUT COULD SMELL THE RACE GAS IN IT
