Supercharger Snout Bushing Rattle
Fuck Carney
So the car has sat for a few months waiting for winter to end and I might have put 30 miles on it so far this year since the weather changed and I am noticing a ticking noise I never heard before. Doing some internet searches has lead me to believe this may be caused by worn bushings in the supercharger snout.
Anyone care to share their experiences or feelings on this ?
Thanks
https://youtube.com/shorts/xfjWTpLOn4Q?si=jBlJhTjEo0j9En-C
Ricky Racer
Vancouver
2018, dodge demon
always start with the simplest part to fix. Tensioner bearing or an idler.
Ta2ude
Fuck Carney
So I decided to replace the tensioner and idler pulley with the Metco product as I did notice that although the bearings seemed ok it was visibly obvious that the belt had been slipping on the pulley as seen by the pictures below.
Ta2ude
Fuck Carney
The Metco pulleys not only looked a lot nicer they were considerably lighter. IMG_7974.jpeg
Ta2ude
Fuck Carney
When the belt was off I took another short video to try and show the noise I was hearing that had me concerned about the bushings in the snout. If you watch the video you can hear a definite “clicking” sound when I move the pulley back and forth.
I am wondering if this is normal or a sign that the bushings inside the snout are wearing. I think there are 6 or 8 plastic bushings inside the snout, that drive pins go into and I believe the noise is an indication that they have worn and are now sloppy.
I was wondering if anyone could confirm or alleviate my suspicions.
Here is a link to the video.
Thanks
https://youtube.com/shorts/RMSPGcaTryI?si=dMtPTJHdGosZe76p
Ta2ude
Fuck Carney
Here is a video that lead me to believe the noise I am hearing could be an issue. If you click the link you can watch it on YouTube.
Ta2ude
Fuck Carney
IMG_8594.png Apparently they used 3 different tensioners on these cars so you have to check and see which one was used on your particular vehicle.
On my car they used the Dayco tensioner, I am not sure what is actually different between the three.
Thanks
How many miles are on the car..
Ta2ude
Fuck Carney
