Inj DC there on the log as well in pictures, usually stays under 70%, I’ve got a bit of head room yet there. I’m running dual 285 pumps atm, have new inlet filters on the way, if they don’t get me head room back stepping up to dual 295’s will. This will keep me until I go Whipple someday.
just do a triple 😭 it will be fun, I promise 😂
Me doing axles 3 times last month looked more fun than being sent a kit with a bunch of wrong parts.
Thread Starter #863
I’d rather eat liver or drive a automatic Camaro first 😂
Thread Starter #864
I'm still stock
Yea, You’re not making nowhere near the heat load we are at 20-21 PSI at 6700 motor RPM on a 2.4. Back when I was running a stock lower and just a 2.85 upper my IAT’s would never go over ambient even after a 1/4 run. What’s needed is a Whipple and their double pass intercooler is tha bomb!!
Someday 🙏
Someday 🙏
Steady state cruise on the highway should be the same work load on the motor though???
Nope, I won't do that, oh , I won't do that
I have done a fuel system and would do it again before those other nasty things:poop:
Steady state cruise stock vs pullied IHI blower yes temps over ambient should be reasonably close but I'm not sure that's telling us the story? It's under WOT that IAT matters yes? Cruising around mine are like 30° F over ambient. No blanket or spacers on mine.
Thread Starter #868
Pulley’d blower is spinning faster for same motor rpm, the blower then started recirculating air it has already processed probably a few times over so one would think it’s creating more heat into the air then stock blower speeds would be doing?
Thread Starter #869
I agree here, what’s most important is what IAT’s get to under WOT conditions and for how long WOT is held for as at WOT AC compressor hence chiller is not working any longer. My hopper tank is designed like a 4 pass heat exchanger, so at 18” long with 1x1” sq channeling inside the 4x4 tube it acts like a 72” long column of cold water, this gets me through a 1/4 pass before warmed up water starts getting to the cooling bricks in the blower. And every inch of everything including the manifold on the back of the blower is insulated with 3/4” thick silicon foam R5 insulation, hoses, pump, tank, everything.
Well let us know how the liver tastes or the Camaro feels. A whipple 3.0 makes 23 PSI out of the box without a smooth boost controller. I know this to be true cause mine is sitting in a dark corner of my house waiting to be installed. A dual pump system is not going to keep up.
Maybe the one off of a Drag Pak but the 3.75 pulley the street version comes with will not make anywhere near that
Who buys the street version? I didn't and I wish I didn't. I learned that the 3.0 doesn't accept the fore fuel rails so I'm married to my 2.4. Mayble I'll post it in the for sale or mayble I just throw it in my drag pak... whoops...
The fuel rail thing don't make sense being you can run the stock ones and only theirs:rolleyes:
Thread Starter #874
Changed pump inlet fuel filters, easy peasy 1/2 hr job.
Quick run down for those that never have done it
Get pumps out, a proper bung wrench makes it easy. simple as twist the lock ring off, disconnect the jet pump line, disconnect fuel feed line, remove float, take pump assembly out of tank.
874D9110-01F7-4F1C-800A-0450AE63869B.jpeg FE4D3196-5EF5-4D73-A4A6-0A81CE7472FA.jpeg D7A9F481-9DE9-4E2D-B9C2-99A0B8E7285D.jpeg 89722D5F-F296-43C6-B24B-34D017BC54D1.jpeg EE7F8E62-1518-4773-B73C-B1CD080F608D.jpeg 18ED9786-46B5-4269-AE1C-E72DF37F9A5C.jpeg A47D9507-7D9A-49B3-A31C-9DC0C1E874C6.jpeg 8F784AFA-F31B-4CFA-B32B-AE16A9173D49.jpeg
Use a push pin removal tool to pry old filters off, snap new ones on, put back in tank in reverse order.
3CA6F632-B978-46A7-9F4E-3E16800D1F1D.jpeg C2B7CD6D-9B27-4604-A1C4-C2C429F62C73.jpeg AC30D4CB-17E0-482A-BF14-1966640E1187.jpeg FD6E422F-539C-4EE7-8638-BCBC00A40E25.jpeg 8DFC2D49-BBCD-4F68-A0E8-D28BFD05DB21.jpeg C67DE559-1499-424F-9D1F-EBB082DE96BE.jpeg
Thread Starter #875
What’s $15 and 1/2 hour of time net?
Fuel pump head room :)
ACC33651-DC59-4A9B-BF33-97BCE3156E4D.jpeg A27B9695-2D36-41F5-8B65-5F941A93093A.jpeg
Thread Starter #876
What that run net?
7E41FAE0-A90A-4CCB-B245-CCA43634F878.png EEED60FF-0052-47FD-86E5-D6A7B7190231.png
I need to get practicing launching again, this 60-130 running I’m forgetting how to launch this thing on the street. Sooooooo close to the 10.99 street goal
What did original filters look like.
Thread Starter #878
Not too bad.
Thread Starter #880
Their 30 micron, can’t see stuff that small but I guess there’s enough of it in there to make a difference. I have 2 new 295 pumps coming to see what that nets as well before hanging a third pump on there. I need a bit more head room to support a small dry shot of giggle gas for inlet air temp and blower cooling :)
