Portable Track Jack Recommendations
How tall is this height from the ground to the lifting pad View attachment 17129 ? 7"? Thanks for the video..
If you don't have the same lifting pad you probably wouldn't need the block of wood.
I have a bin I carry with lug nuts, tools, cleaning supplies and this jack with a block of 2x4. It's one of those trunk organizers from HF.
Ok I was just wondering the thickness of that jack as I lift from the frame rail farther in and not the pinch weld.
That probably gives you just enough room. The frame rail is higher than the pinch weld if I remember correctly.
