Oil Cooler Line Failure
Elkhart
IN
Actually you don't need the tool. Just pull back the plastic clip retainers off and then with a small screw driver pull the wire c-clips out of the hose adapter nuts and simply pull the hose ends out. They are the same design as on the transmission lines.
Any idea where I can purchase replacement clips? Lost one of mine while replacing the lines.
Those clips usually fling into another dimension when you take them out
Any auto parts store has em. Take 1 out of the other line and match up the size. Had to do that with my trans cooler lines on the cooler side
Thread Starter #24
If you're replacing old lines, the new one's will have clips in them. They just push on, when installing. No need to remove the clips, or use a tool.
Hemi Rocket Barge
Hemi Rocket Barge
Commenting on this thread, I have a fuel line fitting that uses these clips, I was wondering if I needed to remove the clip before installing, glad to see I don’t
I am going to put a small wom clamp over it to ensure the clamp stays on
Fore does suggest removing the clip before sliding onto male efi fitting, which I thought was odd. Probably to ensure it’s not bent during install
hmm, I see the difference, trans and oil cooler lines are tapered, so they can be pushed in. These cannot
