- #1720
- 320
- 284
- 37
- Detroit
- Non-US
- Afghanistan
I know it is very high-temperature, has GREAT resistance to water invasion, as it is not hygroscopic. that's H Y G R O S C O P I C.
However, bad news, I fond when I eagerly installed it. The brake pedal turned into a trampoline. This weird stuff is compressible.
No, I didn't have air bubbles in the system. It was properly installed.
Fictitious story: I submerged the whole car in a tank of silicone brake fluid, pumped the pedal on all the open bleeders until the fluid coming out of bleeders ((I had to use SCUBA gear) was clear.
Anyway, yes, i bled and refilled the system properly.
This stuff is terrible at the one thing we require of brake fluid: relatively high incompressibility.
So bad, I regard it as a safety hazard to use.
Now, if having 700 degree temperature tolerance and zero water absorption are more needed in your case than actually having any pedal feel, then it may be what you need. I just wanted to save you all a bit of time and money.
