"Moroso" Palm Beach Raceway
deerfield beach
2019 redeye
I am going to be running my redeye and hoping for 10's. I know I need a driveshaft loop. My last car was a low 12's hight 11's. Anything else needed at 10.99?
lennep
deerfield beach
2019 redeye
I did they referred me to the IHRA rule book. I was hoping someone that has run a 10 sec car there could help.
Most everyone with a stock hellcat/redeye does not have a driveshaft loop. Depends on track if they are looking for it. A lot of stuff isn't looked for on the newer cars
As long as you have tires, 10's should be easy:)
Whatknot
What is a driveshaft loop?
Whatknot
Just incase you Snap it, so it doesn't fall down and dig into the track?
Yes. Don’t need to do any pole vaulting.
WhipCat
In the Jungle
You don’t need a drive shaft loop.
I would recommend a good rear tire like a Mickey Thompson so you can hook up.
I run that strip all the time, I’m like 30 min from it. I also run the road course every week.
lennep
deerfield beach
2019 redeye
I am an hour away. I sure I will see you there.
Back in the old days if you ran I thinks it us 12.5 you had to have one.
When the viper can out a lot of the rules changes. It used to be if you ran 11.5 they started jump up and down saying you have to have a roll cage.
WhipCat
In the Jungle
Palm beach is a super chill racetrack.
Unless it’s a sanctioned competition, than you are good. You’ll pass through tech like nothing
lennep
deerfield beach
2019 redeye
good news Thanks
droptopp
Rochester
Or going through your floor board and smashing your ankles like the Fox bodies used to.
lennep
deerfield beach
2019 redeye
My 2001 camaro drive shaft broke the loop worked... It also broke axels, differential and etc......
