How-To: Cell Comm Killer.
Says my vehicle is up to date
Anyone use the guardian app?
WTF! 885 there but they never finished the job and made it highlight! Pure cheapness/laziness! Absolutely not the quality I, or anyone should expect from a major mfr. Obviously they don't give a crap!
Oh, c'mon. Next you'll want the Lie-O-Meter to show actual mpgs, right?
The one in the GT AWD is over 2 mpg off - in the optimistic direction, of course.
Tolerance of bad behavior is approval of bad behavior.
They promise you this then give you that...
Can I get my money back???
Whatever vehicle I first had with that fantastic option available resulted in many emails from them.
Eventually I got tired of them and called, telling the lady that I had no interest in Guardian. But there are so many great features available, she said. Like what, I asked.
Oh, you can find your car with Guardian, she said proudly. I told her that if I was so wasted that I couldn't find it, I have no business driving it. That ended all the emails for that particular vehicle.
I would've thought that after never having used the free introduction period on any vehicle they'd give up, but nooo.
I see that one, and several other gimmicks, as a source of amusement.
Thread Starter #126
Guardian is the problem we're all talking about, here.
Hemi Rocket Barge
Thread Starter #127
Cooked up a fresh batch of D and H series cell blockers.
Shipped a few out, already.
MY15-MY17 only need D (purple). 100% blockage.
MY18+ can block comms on circuit D (purple) and H (pink), but the aircard still has cell authority, maybe from an onboard backup antenna. At least we can knock out 2 out of 3 comms.
Hemi Rocket Barge
Thread Starter #128
By request, made up a few satcomm blockers.
Hemi Rocket Barge
2ndgen
Orem
Hemi Rocket Barge
So does MY17 need one or two blockers?
A previous post said 2.
Hemi Rocket Barge
Upon first look, I thought they were AK cases with the mouth flattened!!! :ROFLMAO::ROFLMAO::ROFLMAO:
Thread Starter #131
Iirc, 17 is a transition year. Only sure way is to pull the radio, or figure out what radio you have.
Hemi Rocket Barge
Thread Starter #132
Hemi Rocket Barge
All gone, but one.
Have more on order.
Hemi Rocket Barge
2ndgen
Orem
Well I bought it in Jan of 2017, so early build in the MY.
Thread Starter #134
I have a full set of satcomm and cell comm blockers (3). If you want dibs, send me a PM with your address. I can ship, tomorrow.
Hemi Rocket Barge
LA
2019 Jeep Trackhawk
For those of us who value their privacy and prefer not to participate in forced UConnect OTA updates, I have developed a single that effectively blocks all cell comms, inbound and outbound.
NAV and Cell are separate systems and have separate antennae. Blocking cell comms does NOT interfere with NAV. There is also some confusion about Performance Pages. This mod does NOT disable PP. If you have them, you keep them.
In the first month, I experienced 1 bar, 1G bleed. After that, zero. I have had zero cell comms, for a couple of years. Zero issues. Several dealer visits. No problem. You will get a nag screen that you can ignore and it will go away, or you can simply press OK and it will disappear, for the duration of that key cycle.
Things you need:
5 min epoxy
FAKRA D connector (cell comm)
10k (10,000) ohm 7 watt resistor, wire wound
3" square of copper Faraday fabric
1/2" diameter weatherproof shrink tube. About 2" long.
Heat gun, or lighter (to shrink the tubing over the end product).
Lay everything out, end to end, so you get an idea of how this goes together.
Cut down 1 lead, of the resistor and solder it into the signal pin.
Insert the signal pin and resistor, into the connector and solder the other resistor lead to the connector shield.
No picture, but at this point, epoxy the center resistor lead I side the metal FAKRA housing, so it doesn't bend and short.
Once the epoxy is dry (about 15 min), fold your Faraday cloth into a triangle.
Wrap the resistor tightly and slip the shrink tubing over and heat. You will have a little bit beyond the end of the resistor. While hot, pinch this closed.
NOTE: You will have extra Faraday cloth, beyond the resistor. Fold that over, before installing the shrink tubing.
With the car OFF, remove the screen and radio module, behind it.
Unplug the FAKRA D connector (same color) and ugh in your dongle.
Re-assemble radio and screen.
Enjoy your privacy.
Bob
Where are we able to purchase one of these & Im assuming it would work for a trackhawk as well?
Thread Starter #136
Instructions are at the top, for DIY.
If you prefer, I can provide the blockers you need, for your TH. You will need pink and purple blockers, for this application.
Shoot me a PM and we will work it out.
Hemi Rocket Barge
Dallas
Scat pack 2022
Could
If you don't care about radio functionality, this process is WAY easier.
Open the head unit, disconnect the 3 small coax antenna wires, and the 1 ribbon cable that goes from the board to the AirCard. That powers off and disconnects the AirCard completely. Vehicle is no longer capable of TX/RX for cellular (3g/4g etc).
Wrap the ends in insulating tape (like Kapton) to avoid shorts, or remove the card entirely if you prefer. Close up the unit, done.
You'll lose all GPS satellite functionality as well. SiriusXM radio still works. If you dont't want SiriusXM (and any satcomm at all) just disconnect the blue/gold satcomm antenna from the back of the head unit. If you prefer, you can also use @Diboblo 's satcomm blocker.
you help me out
