Hellcat 8HP95 transmission in an SRT?
I know. Some people take "door slammer" to the next level.
Buckshot_Brian
Buckshot_Brian
Johnstown
2021 Durango SRT 392
Thread Starter #22
Since
Have your buddy at the transmission shop buy a gpz clutch and steel set up,along with a new pump ( always put a new pump in ) and have him refresh it at that power level a stock clutch set up will do just fine unless your planning on adding more power , then make sure it’s tuned properly (hopefully your on hp tuner ) if you need help reach out to jonx96 he can get the trans tuned
Transmission coming along! In addition to the RGPZ-020 GPZ friction clutch pack, STMZF22 steel clutch pack, and pump, we are also replacing the problematic "A" clutch backing plate with this billet version from Sonnax: https://www.sonnax.com/parts/5340-heavy-duty-a-clutch-backing-plate
SansMor81
Military Veteran
Durango SRT 392
How did the build go? I am looking to possibility go down this route as my transmission is starting to whine as well. Did you also upgrade the Transfer Case?
Sorry, but OP hasn't been around for over 2 years.
