Getting off the line. Help!
Causation is not correlation. If you are logging the correct channels and the throttle body is opening at WOT then you are bleeding boost and the motor is failing. Can happen at any boost value above stock.
He means bypass opening I think.
You can see in the logs if it's opening. Compare bypass voltage 1 and 2 I think they're called.
However a 2.5 upper and 10% lower should be more than 18 I think. My 2.72 upper stock lower was 16.
D
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
Thread Starter #143
Yea...ure right. Got a link for wherr you got yours?
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #144
Im just 2.55 upper. Stock lower.
From those pics I don’t see belt slip, at least not an abundant amount. If you wipe your finger around the thermostat housing does it come back black and cruddy? Doesn’t look like it would. Belt slip makes a mess.
I have belt dust on mine just from wear from the pulley so it can be hard to measure that way. I had a pulley many years ago that was very aggressive and the 1st drive of 30 miles there was a ton of belt dust and I never got on it. It was like a cheese grater
the bypass valve can be a real mother bugger!
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #148
Here are 3 logs ive also sent over to Jon.
Side note :Would the catless mids have anything to do with the boost being lower? I know headers do.
I don't think mine showed lower boost with cat deletes back when I tried them stock. You will see a bigger difference in DA. If it is cold out the boost will read higher
Hmm…
oilburner
coboconk
Those don't appear to be drag strip logs. Can't compare apples and orange :)
you can but I would rather have blue berries:p
I agree, that’s usually a finer dust. With griptec pulleys they usually make bigger chunks, right?
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #155
Correct itll be weeks before im back at the track
Jon-MooredPerformanceLLC
Martin
2018 Dodge Challenger Hellcat
Well log to was showing a lot of knock. Also one of the logs showed fuel trims from bank 1 and 2 were way off. Also at wot fuel trims are pretty rich and need straightened out but I doubt before signing off I didnt have them dialed in closer. The fuel you are using is good e85? I need to send another list so we can see what each injector is doing individually. From what I see you arent hitting injector pulse limit but your duty cycle is 75 %. I will email you another list I thought I sent you this list last time but I guess not.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #157
I loaded the list you sent me. Fuel is testing out betweem the 80 and 85 mark. So E82. 5? Lol
Martin
Ya thats not going to cause what im seeing here. Really need to see each injector. Maybe there is a dirty injector. Been having that a lot this year.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #159
On the road today with fiance for her first cruise. Ill be back 15th. Will load up the new list and log
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #160
Another 1/8 mile run. This track was less sketchy than the other one I posted. Ill be going back here.
