Front license plate holder
2020 Indigo
Vista
2020 Dodge Charger Hellcat
Besides stock, what is everyone using for a front license plate holder?
T_Trahan44
Spokane Valley
2012 Challenger SXT
Welcome to the site.
Got any pics of your cat (car)?
No worries for Ms, as it does not require front tags.
NY requires them....most all have them...with the exception of most performance or collector cars...my DD's have them..my other cars do not..never had an issue...never got the point of sto n go....when do you sto..and when do you go..:unsure::unsure:
By the way 2020...welcome to the playground...
Sto at a show,
Go when you blow....
Blow: to go.......
HWDan
Home of the Hellcat
2017 Charger SRT 392
this ...
https://stonsho.com/2019-2021-dodge...r-t-plus-and-daytona-and-2019-hellcat-sns66f/
It mounts in a good spot and no extra holes to drill.
If you already have plate holes drilled, the black part of the bumper where it mounts is just a plastic trim insert. Pop it off with a trim tool and replace it with a new one. maybe $80 or less, I can't remember but I replaced mine as it was drilled.
Sto at a show,
Blow: to go.......
seems kinda useless
I used this one on my Challenger. It's got many ways to adjust it to your needs.
It's a Bozzmount MG
https://www.slybrackets.com/store/B...comb-Diamond-Hexagon-Perforated-etc-p80520617
Here's pics from my install:
I installed the mount bolts through these holes, but you can adjust to whichever ones you want.
This is what it looks like
This is what the mount looks like; but you can change the configuration to many different ones. I actually had mine switched around so it was mounted upside down. You can make this one pretty much do whatever you need to do. There are rubber spacers on the mounting posts so that it doesn't mark up the plastic.
And if you decide that you want one of these mounts....let me know. I removed mine from my car when I sold it, so it's sitting in the box in my garage and could use a new home.
Piening2150
Toledo
2017 Charger Daytona 392
Thank God Ohio finally did away with the front plate requirement... Not that I ever put one on anyway...
How strict are they about it in CA?
you can use the lower grill with wire ties on either a Challenger or Charger
Taxinator
SANTA CLARITA
2017 Charger SRT
Fairly strict...only a matter of time for those running without a front plate.
Another vote for the Sto n Go n Sho n whatever it's called lol. Love it. Pull a pin and it comes right off for shows or cleaning. Never touches the paint, re-uses a couple of existing mounting screws. Total win.
1BEC4756-B6AE-419B-9590-ED4B40998414.jpeg 9D1539B8-C2DB-43AF-8D4F-F1AB2108433F.jpeg
2020 Indigo
Vista
Unfortunately Cali requires one, plus I drive it on to the Marine Base every day and they check. I saw the stonshow, but I had one alot like Stormtrooper showed. I just prefer something low on the front grill.
2020 Indigo
Vista
Hey Devil Dog if you got one that you want to get rid of Id certainly take it off your hands.
Gotta be careful when obstructing airflow to the coolers behind the grille down low…
PM sent
Prange
no longer in Chicago
2021 Charger Scat Pack
Strict in Illinois,too.
