Catch can for a whipple 4.5
jakeh1
grand junction
2016 hellcat
What is everyone using for a catch can running the 4.5 whipple ?
I ran a jlt on my stock setup and it doesnt look like it will work on the whipple set up.
I would think the fender mount upr would work.
I have tried other catch cans with no luck. The upr seems to be the best.
22MoparMuscle
Chicago
2022 Challenger Hellcat
Are you guys talking about just the regular Hellcat Challenger with 717 HP?
Do yourself a favor and get one of these. Remote mounted. Uses a -10 line from each valve cover and vents crankcase pressure at the top of the can thru the filter. There is no oil returning to the intake. D70D20D9-0E5A-4215-A3E9-DC6897CF7A10.jpeg 2D0A7210-7977-47DB-BFEE-9C747C4791C2.jpeg
22MoparMuscle
Chicago
Do yourself a favor and get one of these. Remote mounted. Uses a -6 line from each valve cover and vents crankcase pressure at the top of the can thru the filter. There is no oil returning to the intake. View attachment 73313 View attachment 73314
I seen one similar to that but it had a pulley on it. One reason, so it would fit.
Not sure on how a pulley would work but this is what they call clockable. The mounting bracket can be positioned 360 degrees around the can so it can be mounted in any direction to accommodate the direction the hoses need to go.
22MoparMuscle
Chicago
