A8 1-2 shift
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
Never had any issues transmission wise with this vehicle. Now im getting a weird 1-2 shift. Does it no matter what. Even if i manually Shift it at a different RPM. IT revs up between the shift. The easiest way i know to explain it is its like driving a stick shift and not letting off the gas pedal when shifting. Any ideas?
How is your racing tune set up?
I found this happening to me when switching from DD to my race tune.
It was me not watching my race page while drag racing.
D
Demid22
Nurse
JONESBOROUGH
Per the tuner, nothing has changed between one tune to the next so Idk if its that.
Mine is doing the same thing. Cram more fluid in it
Low line pressure
I have a case of fluid, going to cram more in there before next time out. 1-2and 2-3 shift. 2-3 shift just didn’t even happen pedal went dead and engine went to redline
Yes, I have different tunes for DD and another for racing.
So it isn't anything about my Tuner.
It's me.
Sometimes everything is perfect and other times it's not.
Do you have the double tap for custom race mode setting?
D
Demid22
Nurse
JONESBOROUGH
Is there a PID to log line pressure?
Not sure, just overfill it. Won’t hurt anything. All the builders do it
My tuner recommended I overfill it, also. I know mine is probably a bit low because I did a transmission swap and completely drained the cooler
Sorry, reading this tripped one of my triggers...to the ZF engineers: put a F-ING dipstick in these transmissions you idiots!!!! :mad:. Now back to the regularly-scheduled discussion...
Fun
Fun fact, a company makes an aftermarket dipstick for the ZF in the bmw (also no factory dispstick) It’s just a tube that screws into the plug and goes up to the firewall. Someone needs to make the same thing for these.
If someone came up with a high-quality design for our Dodges', I would be a buyer x 3 in a heartbeat!
2021 Jeep GC 5.7 TrailHawk
I would take it the dealer if it’s covered under your warranty @Demid22? The ZF8hp70 was doing that in my 2021 5.7 Jeep GC and it got worse to where if you were getting on it, it would completely miss 2nd gear and rev up. They said it was not serviceable and replaced it. The trans came with a new torque converter
I wonder if a guy could design up a profile, and a really simple die-set and a 3D bend profile to follow, then find an OTS dipstick to combine along with it and then, presto!
:unsure:
I’ll take one please for whoever wants to make one. For as cheap as this one because it’s the same freaking thing.
:unsure:
Presto...Presto???:unsure:....ya seen one too many vegematic commercials..:rolleyes::rolleyes:
Fun
Why? unless you have a bad trans or leak it isn't going anywhere
T
o be able to overfill it easily and fill it easily when you service the transmission.
I have a case of fluid and I’ve been putting it off for a few weeks now because I don’t have a lift anymore
