Should I get the check engine light when I don’t have TPMS in my rear tires?
Rear drag radials, no TPMS, I get the Check Tire warning but should I also get the check engine light? There are not DTC’s showing. Thanks.
2021 Jeep GC 5.7 TrailHawk
No. Only the TPM light will come on
Thanks Silver. Wonder why I’m getting the cel without any codes. I just removed the mfer exhaust valve kit as I was getting that P121B code and it wouldn’t pass NYS inspection with the cel light on. Removed them, no codes, but light still on. Wonder if I’ve got to drive the car a few miles, or cycles, for the light to go off.
Follow-up. Zautomotive to the rescue. Active exhaust delete modules cleared the code and turned off the CEL. Haven’t put the scanner back on yet to check for anything else. Hopefully I can cruise the NYS Inspection as Registration is up next week.
