Remove bottom of rear seat delete
Anyone remove the bottom of their mopar rear seat delete without destroying it? Doesn't want to budge without crunching. Looking to redo a few in tank butt connector for the fuel sending unit. Any pointers would be appreciated. Thanks
Walland
23 Challenger Demon 170
Yeah it’s tough but when I put mine in I slightly opened up the receiver grove still wasn’t fun.
Saint Paul
Dodge SRT Demon
Anyone remove the bottom of their mopar rear seat delete without destroying it? Doesn't want to budge without crunching. Looking to redo a few in tank butt connector for the fuel sensing unit. Any pointers would be appreciated. Thanks
I used this
As a pry tool.
Popped right up
Does it engage with the seat brackets in the same way the seat does?
Push back, pull up? Easy with the right move, 'won't come up without that backwards push first.
U
Tired backwards push and pulling, still nothing. Used a trim removal tool. Lifted it up high was I could be hand until I could locate the plastic clip. Lifted up on the side of the plastic brackets
U
And all of that for nothing! Pulled the pumps and the heat shrink butt connectors I used look great after 2 years, better than the ones that came with the pumps did before I had to replace them. Zero degradation, and were hard. So not dissolving while sitting in e85. Threw the pumps back in, fueled it back up (drained with my relay and hose off the rails). At least now I know I don't have to worry about it.
