- Member ID
- #1155
- Messages
- 11,913
- Reactions
- 20,154
- Likes
- 352
- City
- West Texas
- State
- TX
- Country
- United States
- Vehicle
- 2017 Charger HC (once upon a time)
So, amongst all the other work related things I had to do today, I took the Charger to the wheel and tire shop I use and have them pull my other two OEM wheels (that are in their storage room) and dismount and dispose the old OEM tires on them. Then we pull the new rubber off the to fronts (the one that is out of round, and the other that's just a little off). Balance the set up, doesn't look bad. This work was done by the managers, personally, at no charge. Put it back on the car. Later, after more work related stuff, I take it for a series of tests. It is worse than before. As you pass the 110 mark it gets pretty damn scary actually. But under 80, it's just butter.
Here is the kicker: while the front is off the ground I inspect the rotors. Starting to get a little lip at the edge as they're wearing (after three years, not too bad - have pics, won't bore you). However, on the right side, where we had the wheel come apart (as one of you observed, looking like a lathe had been taken to it), I found what looked like a strap hanging from the brembo calipers. When I investigated, I found this was an 8' long piece of tire, almost 1 cm by 1 cm in cross section. It was wrapped around the inside hub, behind the rotor, and was a son of a bitch to get off. So that's where at least some of the lathe droppings went.
So, this is my off the cuff thinking.
1. The two new tires are bad. Simply can't be balanced, will have to go back to the seller for replacement (which I'm sure will be a fight).
2. The "latheing" near-blow out (or the impact that threw the wheel out of our round) completely screwed up the alignment so bad that over 80 it's just completely F-ed.
When I return from New Mexico I'm heading to my other friends shop to have them check the alignment and balance. If its all good and we're still trying to shake the car apart, off the tires will come. Share thoughts if you think I"m missing something in my thoughts (I'm old remember), if you want to just offer your experiences, or if you want to call me a dick. It's all good.
Not that this would have been under warranty, but it really is suspicious that this all happens the instant the car is "mine" for real and not a lease anymore.
