Launch mode not holding
Blaze
Slidell
LA
2025 Dodge Durango hellcat
I have a 2025 Dodge Durango hellcat when I first got it after a few hundred miles it allowed you to use launch mode everything worked perfectly. Then I went to the dragstrip and it simply would not hold so I read light multiple times I took it to the dealership. They are telling me that the car is sensing slippage of my tires to the ground so it is allowing the brake to release. That doesn’t make any sense to me. I have another vehicle with launch mode that I can sit there in gravel and as long as I hold the brake and floor the gas pedal it will not go anywhere. Does the launch mode on a Dodge work differently than any other cars launch mode or is the dealership giving me the runaround?
Wizza
Stafford
VA
What rpm do you have it set to?
B
Blaze
Slidell
LA
Had it at a pretty low setting whatever it was from the factory and it was working once we went to the track and noticed it stopped working then we started playing with the RPM bringing it up and down. The dealership took me from 50-50 front and rear switched it to 60/40
then put the RPMs all the way down and they claim it was working in the parking lot. It is the wife’s vehicle she picked it up. She did not launch it after she picked it up. I just tried today and it’s doing the exact same thing. Basically you hear the RPMs coming up but the car is creeping forward almost like if you’re just old-school power breaking.
06SRT10NR
Knobnation
don't care for launch control on anything I've played with, so this guess is likely wrong. Do those settings reset to default when the vehicle is shutdown?
Welcome to the forum from the Mississippi Gulf Coast.
Got any pics of your ride to post?
Mine is only a 392 SRT but the few times including my PB 1/4 mi between the corn fields the launch control has been outstanding and impressive.
Stomp and hold HARD on that brake pedal and do not let the power leak. I mean hold that sucker down harder than you think. You learn that extra pressure on road courses attempting to slow Hellcats down.:love:
Pump brakes prior to initiating LC.
Stockton
MO
2024 Durango SRT AWD
Ran my 2024 392 at MOPARs Invade last weekend - the brakes would not hold the launch control. Went through the lights the first time, they let me back it up and restage. Second time I was expecting it and caught it before I jumped the light. Third time just gassed it at green and got my best time 13.18. My AI consultant suggested the PowerStop Z26 front pads would help with the issue. Also, my brake pedal was going to the firewall, so pumping it would have been the thing to do! Will check my master cylinder and brake fluid but really came here for confirmation of the brake pad advice.
