Front tires
2020 Indigo
Vista
2020 Dodge Charger Hellcat
ok its time for new tires on the 20 Hellcat widebody charger, but Im thinking I want to put drag radials on the back. Ill probably go back to Nitto 555rII but I dont think that would work real well on before. On my challenger I put nitto 555 G2s which worked. Problem is I cant rotate tires with this set up. So I was wondering if anyone had a idea of good gripping rear tires that will also work on the front. Any ideas would be helpful
The super stock has drag radials on all 4 😊
But if you are looking for a non drag radial I don’t think it gets any better than the ps4s. They won’t hook as good as a drag radial but they hold up pretty good on my e85 hellcat from a roll compared to factory tires. They get pretty stick and are fairly soft. If you want a tire on all 4s go with those.
