First time out in my 2019 hellcat
Loveville
2019 challenger hellcat
Plumcrazy1320
Loveville
2019 hellcat challenger auto only mods forgestar d5 front and rear wheels. 4655lbs with me in it 1440 da. Car number 323 on the time slip. Is this the normal for 2019s? My 2016 ran 10.86 same wheel setup in negative da
Others with direct experience will have to answer, I've seen a wide range of times from around your old time to your new time.
God I wood hope so. Take it back. Bullish on times,,, tell him.
2021 Jeep GC 5.7 TrailHawk
There were some thoughts sometime back about 2016’s having a little more aggressive stock tune than later models? With that 60’, I assume you had some drag radials? Was that run at MIR? MPH seems a little on the low side. For comparison, Vortecd just reported a 10.99@126 in similar DA in Michigan with a stock full weight 2016 Charger just with a green air filter and 275/50/17 DR’s. His 60’ was also almost the same.
Plumcrazy1320
Loveville
Yes it was mir it has p30545r17 street r drag radials
MIR is a fast track. It will do better. What was your custom mode settings?
Plumcrazy1320
Loveville
Traction off trans track suspension street steering street 1500rpm foot brake. The mph concerns me I know da affects it but 4mph seems like it’s pulling timing? I’m running 93 octane would unleaded race fuel help when the weather isn’t good?
Hickstah hea. 93 oct good,, 110 leaded not good unless you want to blow out your catlyst ic per verters, fuel pumps, exhaust gaskets, a many fuel rails and many other parts that will BURN out. Learned the hard way about gas ole ine allys that are selling race fuel unleaded and happens to be $8.88 leaded fuel. The car does not like that crap at all. The ally was even advertising it as unleaded until I threatened to sue. Young kid finely came across as to what it was. Usually sold close to a track. Will mess up quiet a few female parts. I was lucky, viewers will attend to, know I got away with the FCA rep and dealership backing me up,, as to spending too much $$$ for this con trap tion any way. Just be care fuel when these codes blow. Have a story in pocket and in my case take the rep from up north to a good grouper sandwich shop in Fl. During the winter months. Blamed the problems, all paid for, on the K & N CAI. Most expensive ever installed.
Confuzed1
Go Pack Go
ET of 19.6 for first time out.....not bad! ;-)
Matt someone with an SRT
Newtown
That was me on my motor scooter, lol
Decay
Astoria
2019 widebody Redeye
Stay with it , some times my car has to figure out what I'm trying to do and after a few passes it gets it.
So, I think you will probably pickup .5 sec. JMO
Maybe the '19's don't have as an aggressive tune being they are speed density? I know someone that took out a '19 last fall in 500 DA and ran 11.1@124
Also did you run both lanes? 1 lane at our track last year was 2 mph higher. I was trying to do some air filter testing so I ran the right lane every pass
Congrats OP , good for first time out but your car is heavy , how much gas was in it ?... high DA vs. negative DA is a hp killer , for every 800>1000 DA difference , is a tenth in ET.
Confuzed1
Go Pack Go
Cmon....11.1 does not sound like "its too slow" by any means...right? I mean 10's aren't far away, and its basically all stock. The wheels were mentioned...depending on how tall or short they are would effect mph....or no?
Gas was cheaper last year, which in tune time, meant it was time to change,, Bull, let the cat out. Yea time to change.
Plumcrazy1320
Loveville
Thread Starter #19
The three passes I made were in the right lane. Car had a full tank of gas and I’m 250lbs lol.
How much fuel in your tank and your weight over mine is over a tenth. I run with under 1/2 tank
