Diamond Pistons DLC Pins
Set of 8 new in box H13 Tool Steel DLC coated Wrist Pins for Diamond Pistons. .927” diameter x 2.500 long with .225” thick pin wall. These pins DLC coated cost 87.50 each, selling the set of 8 for $500 PayPal’d and shipped. My loss your gain. I went with a custom WISECO piston with a narrower heavier wall DLC pin. These pins can be cut to a shorter length if needed by Trend for $7 per pin.
4AA9F9AA-9A26-4851-863E-D9D7B23837A5.jpeg 49473056-8273-4D6B-8EF2-689D7F66522B.jpeg 87B9A225-19A8-4ABA-BF0C-9BCF85DAD071.jpeg
Thread Starter #2
Still available. Don’t use inferior 8620 pins supplied with Diamond Pistons when you can get these for just a bit more. Inferior pins will wallow out your pin bores from flex and you won’t even know it until a failure occurs.
Massachusetts
Hello
Sent from my S56 using Tapatalk
Hello
Yes? You interested in the pins? Their still available.
Check Avatar details...
Sorry...
