Battery Negative Jumper Post
south orange
durango
anyone know the part name/number for the cap that goes over the negative battery jumper post? thanks.
Does such a thing exist, and if so why?
06SRT10NR
Knobnation
never heard of, or seen, a negative jumper post cap. no need to have one on the neg side
I have a theory:
Bots are searching questions on the net and posting them into forums to "learn" how to deceive humans. We should stop responding to anyone who never made a proper introduction, otherwise you are helping Terminator... :ROFLMAO:
My ‘22 JGC came with one. Don’t know why.
HWDan
Home of the Hellcat
2017 Charger SRT 392
For this use-case, a condom is the best.
Use a zip tie to retain it but spit on the post first as an anti-rust inhibitor. But don't cut the loose end of the zip tie off. It will help wick away moisture to also guard from corrosion. And if you need to use it, use a tiny screw driver to release the zip tie. Then when done, you don't need to waste a new zip tie to re-secure it. Just to be clear, I'm not talking about using the post, I'm talking about using the condom.
I have a theory:
His user name checks out - might be onto something
It is recommended that it is better to not cover it. Also FYI if you find a negative battery jumper post just paint it red with a magic marker. A little secret, always attach the positive lead to it then find anywhere to attach the negative lead like the engine block. Enjoy, because that always starts something fast.
Please check yours, apparently you are in Spain now! :ROFLMAO:
No ICE in your neck of the 'hood yet?
From a guy with a question mark flag under his moniker! :ROFLMAO:
WTF is going on? Is someone having fun messing with the flags?
Next up: Rainbow Flags for everyone!!! :ROFLMAO:
Not pointing fingers here, but that someone's initials just might be BULL.
