- Member ID
- #1177
- Messages
- 133
- Reactions
- 258
- Likes
- 87
- City
- Central
- State
- MN
- Country
- United States
- Vehicle
- 2016 Challenger Hellcat
6.2L motor and heads: $3500
Stock motor and heads out of my ‘16 Hellcat. 4200 miles on them. The stock supercharger rotors failed and grenaded so a small amount of debris was ingested into the motor and took out the rings. A rebuild will be needed but no major damage was done. I’ve had a new 426 and Thitek ported heads so I no longer have a need for the stock setup. My plan was to keep it for another project but it’s just not going to happen anytime soon.
A leakdown test was done and the #7 showed the worst at 30%. That rod/piston was pulled for inspection (see pic). My builder/machinist said the motor looked in great condition and would be an easy clean up and refresh. Rings looked like the only thing to take damage.
Included will be the block, crank, rods, pistons as you see them (removed #7 will be included and is boxed up), no cam. Heads are as you see them and don’t appear damaged but you should have them gone through.
I also have the stock exhaust manifolds and stock crank pulley if you want them at an additional cost.
$3500
$3500
